I’m getting ready to buy a leftover 2016. Can anyone tell me why they switched back to the SOHC 686 from the DOHC 708. This makes no sense to me and I was wondering if it was for some sort of major problems with the 708.
I have a 2018 708, and I can tell you you are not going to "smoke" a 686, they are essentially the same bike. With clutch mods, such as i have, yes I'll get the jump, but if that 686 had the same clutch work, again, it's even. Top speed is the same on both, and they reach it fairly fast, so that's a moot point.True, my 708 will smoke any pre 2019 Grizzly 686, I haven’t gone up against a new one yet.
If you go up and look at post #32, you'll see that I posted about the part numbers being the same on the 686cc engine starting in 2014. 2014 is also when the compression on the 686cc went to 10.0:1. When the 686cc came back in 2019, that is when the 6% gear reduction was announced but what is not known is if there are fuel mapping differences starting in 2019... and I'm tending to believe there may be only because all manufacturers are continually faced with EPA restrictions. Air intake is completely different between 14/15 and 19+.True, my 708 will smoke any pre 2019 Grizzly 686, I haven’t gone up against a new one yet.
Pretty sure you will need the computer and custom motor mounts. The frames are different between the pre 16 grizzly and the 16+ kodiak, they use the same a arms, but that about it.So i have a 16’ kodiak with a blown motor- pistons cracked and junk. What would it take for me to put a 686 motor pre-16’ into this 2016 kodiak? What other changes besides the physical block/motor?
Hello, I know this is a little off topic. I have a 2016 Wolverine r spec with a blown 708cc. I am looking for some help if it's prossiable to put a 2020 Kadiak 686 engine in the wolverine. I see there is some differents with wiring harness and oil cooling. any ideas or help. Thank youI have a 2018 708, and I can tell you you are not going to "smoke" a 686, they are essentially the same bike. With clutch mods, such as i have, yes I'll get the jump, but if that 686 had the same clutch work, again, it's even. Top speed is the same on both, and they reach it fairly fast, so that's a moot point. Sent from my Pixel 5 using Tapatalk
