2021 front diff pinion question
2 reading
1.5K views 6 replies 3 participants last post by  reogem
#1 ·
Have a 2019 Kodi that has developed the somewhat common pinion seal leak. It has been my experience that beside the seal the coupler will need to be replaced or I will need a Speedi-Sleeve to fix the issue. The sleeves are half the price of the coupler.
So my question is because the coupler on the Kodi is different from the Grizzlies and I don't have a caliper here to measure it.
Does anyone know the diameter where the seal contacts the diff side coupler? I need this measurement to order the Speedi-sleeve.
I have owned 3 Kodi's since 2016 but frequent Grizzly Central forum as I started there many years ago.
Thanks for any help.
#3 ·
About time we see one of the most knowledgable Grizzly forum members finally cross over to the Kodiak forums!
Nice to see on here bud!
Reactions: reogem
#4 ·
Hey @Vincent....Joined this forum in 2017 but I guess I'm a creature of habit.
I do favor the Kodi over the New Gen Grizzlies I like the smaller stance of the Kodi it is same stance as my 2013 Griz. I did have good luck with the 708 and I didn't mind the the manual 4wd shifting and hardly ever need dif lock. Although I am riding a 21 Griz SE now. I've only been riding it in the high desert without width issues will see when I get back on the 50" trails. It does have push issues in the corners. Getting rid of the Zilla should help.
I'll try to check in more often.
#6 ·
The best thing to break that red is heat, you don't need a lot of it but a short while even with a propane torch will allow you to get it off.
On a side note, a friend had a starter on his truck where the bolts kept on backing out. He got tired of tightening them so he used a tube of red loctite on each bolt when he put them back in. He then called me when he couldn't get the bolts out to replace the starter. I snapped one of the bolt heads before he told me about the loctite on it. The second one came out fairly easy after I heated it up some. I then thought that we were going to have to drill the broken bolt, happily a piece of it was sticking out far enough to get a pair of vice grips on it and with a little heat it came right out.
I educated him about blue and red locktite that day.
Reactions: reogem
#7 ·
I'm not sure if heat could have been used inside the coupling. Didn't know it was red until I got it off. I was able to strong arm it off with a breaker bar. Had put a couple mounting bolts back in to hold the diff. Hardest part was holding the coupling as I don't have the special tool to hold it just a BA pipe wrench and locking the brakes. I'd foresee this being the last pinion seal I ever replace so I going to look or make a tool to hold the coupling
This is the 4th seal on 4 different machines I've replaced over the years. First with red on it.
