2018 kodiak 700 se
So I have a problem one of my front tires is wearing funny compared to the other. I would like suggestions on what might be wrong. I’m in the process of replacing and I don’t want to stick a set of brand new tires on the bike and have them rear down the same way.
New at this hopeful pics went through.
Automotive tire Tire Water Automotive wheel system Auto part
Tire Automotive tire Water Auto part Automotive wheel system
All-terrain vehicle Tire Automotive tire Vehicle Motor vehicle
I have seen much worse on other. Any chance this machine does lots of identical turns on pavement? That might lead to uneven wear between the two tires. Alignment should help some. Good luck with it. Be sure to check out the tire threads!
2018 kodiak 700 se
Thanks for the info . I guess i'll have to get my riding buddies involved in this project.
Looking at the picture again it looks like the tie rod on the right side needs to be adjusted out, to correct the toe in
