V-belt drain plug
5831 Views 3 Replies 3 Participants Last post by  Grantm
I was into some deep water over the weekend and as per owner's manual, I removed the plug ( 8-41). I can't get it back in. It's a rubber plug with a recessed groove. Trying brute force to put it back just closes the groove. I tried some silicone spray but no luck.
1 - 4 of 4 Posts
Try some motor oil or grease. The silicone sprays don't work well on rubber and it even swells or makes the rubber soft.
grease should work quite nicely to slip it back in, maybe try using a fine point as well to get certain areas in
Thanks Rollin and Muddin,
I applied some white grease and here's what happened.
I tried and tried to insert this "cone-shaped grommet" without luck, and I walked away (ran out of descriptive words) and had supper.
I went back to it and resumed squeezing, pushing, etc.. and all at once the middle of the (coned-shaped grommet) fell out and the two pieces looked like a plug and a regular doughnut grommet. The doughnut grommet went on and plug went in a minute, and all is right.
Seriously, apparently some mud / grit stuck the plug to the grommet and the whole thing came off, and the grease did it's job!
It's funny,now!
1 - 4 of 4 Posts
