21 - 40 of 79 Posts
u can also take a multi meter to the spot where the fuse is and see what it is taking in for amps.
2021 Kodiak 700 Stock 2019 Kodiak 450 1.5” lift on 27s 2018 Kodiak 450 Stock
Discussion Starter · #22 ·
I’ll do that tomorrow and see what I get. I was hoping it would dry out and fix itself lol.
On using the meter to check amps, make sure that the amp reading on the meter goes higher than the fuse in the circuit.
Also I'm not sure if you did it or not but never place a higher amp fuse in place of a blown one of lower amperage or you may end up with a major wiring problem
worst case scenario like i had on my honda, a frame short by the gas tank, in my opinion, Yamaha is better than Honda, especially in cable management and quality
Discussion Starter · #27 ·
Well it’s the pump. Do I need to buy the whole assembly for $350 or can I buy just the aftermarket pump like “Quantum” Pumps for $70? I assume the issue is just the pump itself……
For OEM it is the whole assembly. I'm not sure if a aftermarket one would fit.
I'd try Ebay for a part-out one
Reactions: bachman44
Discussion Starter · #29 ·
I ordered the whole assembly and it works fine now. I guess the old pump was shot and working too hard. 10 amp fuse no longer blows. Anyway, I decided after this that I need an ATV that I don’t do stupid stuff too. So I am picking up a 700 on the 11th and I’ll put a snorkel on the 450 and just continue to send it.
Glad you got it fixed!
now you can start tweaking that 700 with better tires, different clutching… lol! Pretty soon you will be doing dumb stuff on it, like the rest of us!
Discussion Starter · #31 ·
Lol you’re already a bad influence and I don’t even have it yet!
Discussion Starter · #32 ·
Now that I have the fuel pump issue fixed, I’ve got something else going on. Once both of the 450s got about 150 miles on them, a weird bearing noise started at idle. Tap the throttle and it goes away. Gets back down to idle it come back after half a sec. didn’t really care since they both did it. But, now the one I ride is loud. My buddy tonight actually turned his machine off thinking something was wrong. I thought for a second that it was a heat shield rattle and the idle vibration was just the right speed to get it hittin something. But I’m not thinking so…. Runs good, engine break is good, belt isn’t slippin….
I probably have my head 'lodged up my' on this one but here goes. My 450 made the most annoying metallic scraping/grating sound with a vibrating sensation on throttle lift off suddenly most noticeable while descending. Thought it was coming from the rear diff, dealer said it was normal. Finally noticed that if I touched the rear brake pedal it went away. After multiple adjustments to the brake cable tension the noise went away.. of note when I over adjusted the cable it then vibrated at idle. Probably not your issue but worth a try. The noise was highly irritating much less noise now. Check the rear wet brakes... just a thought.
Discussion Starter · #34 ·
Got the 700 today. Completely different animal than the 450s. Currently taking a break. Putting a lift on the red one. I need to get the springs compressed and I about tried ratchet straps but came to my senses. All I have is a compressor for large auto springs but I’ll get it to work. May or may not use a grinder so shave a bit off of the compressor height. I have a rear cv boot to replace yet too.
Tire Wheel Vehicle Car Automotive tire
Tire Wheel Vehicle Automotive tire Hood
Got the 700 today. Completely different animal than the 450s. Currently taking a break. Putting a lift on the red one. I need to get the springs compressed and I about tried ratchet straps but came to my senses. All I have is a compressor for large auto springs but I’ll get it to work. May or may not use a grinder so shave a bit off of the compressor height. I have a rear cv boot to replace yet too. View attachment 10926 View attachment 10928 View attachment 10929
Quick question, how does the left rear heat shield behind and near the foot well look on the 700 from the factory?
Discussion Starter · #36 ·
Hood Automotive tire Motor vehicle Automotive lighting Automotive design
Hood Automotive tire Automotive lighting Trunk Motor vehicle
there is a little above the dipstick access door too. There isn’t much.
Discussion Starter · #38 ·
The red one is fighting me the whole way. When I took the right rear wheel off, I noticed one of the belt cover bolts didn’t look tight. I put a socket on it to check the size and it pulled right out. The end of the threads snapped off inside. 🤦🏻 Drilled it out and I’m going to tap it just to get the shavings out tomorrow. I do have a question, would the 450 be able to get out of its own way if I kept the gearing stock with 27s?
yes, I think Yamaha even sells a set of 27's as aftermarket with 14 inch rims, i seen them for the 700 too.
Discussion Starter · #40 ·
I’m going to get some 27s for the red one then. I’m also going to snorkel that one. I probably better get some wheel spacers too although I’ll keep an eye out for a deal on new wheels with a wider offset. Projects and repairs caught up with for now.
Wheel Tire Vehicle Motor vehicle Automotive tire
21 - 40 of 79 Posts
