Low range is always best while riding at prolonged low speeds, especially when towing, hauling, working etc... . It will help prolong wet Clutch, sheave and belt life.I pull a #450 brush mower for pasture cutting. Throttle control is steadier in high at approx 4-5 mph and takes an hour and half. Should I be in low?
I was thinking about this the other day when I was bush riding in my 18 450. Much of the time I'm crawling at 5 to 9 k or so over roots etc. Is this ok to do for long times in low gear? With a load? Would a slug kit be a good preventative maintenance item?Low range is always best while riding at prolonged low speeds, especially when towing, hauling, working etc... . It will help prolong wet Clutch, sheave and belt life.
Yes the shim kit is on the way. If I can find the right brass weights, I might just do the wet side clutch while I have things apart for the shims. It seems like a low cost, low effort preventative thing to do to improve clutch life prospects. Although I imagine you're in a similar type of boreal shield terrain as I'm into, so if you've gotten away with stock wet clutch, I might as well.Low gear is always best for that application, it will help and prolong your CVT's components. I often use my Low range, especially with riding under 10km/h. That said, my area has alot of rough trails, hills and rocks.
I have no experience with slug kits myself but have heard alot good things about them. In my opinion they are not a " must" simply because you use your Atv for towing.
One thing that mite be beneficial is adding shims to your primary sheave as to get you starting in a slightly "lower gear" sorta speak.
There are many thousands of hard working, hard playing kodiaks and Grizzlys out there with 15, 20 and even 30 000kms, all running their original wet clutchs without slugs. They are not a must have item for wet clutch reliability.Yes the shim kit is on the way. If I can find the right brass weights, I might just do the wet side clutch while I have things apart for the shims. It seems like a low cost, low effort preventative thing to do to improve clutch life prospects. Although I imagine you're in a similar type of boreal shield terrain as I'm into, so if you've gotten away with stock wet clutch, I might as well.
