Im looking at maxxis 27-9-12 fronts and 27-10-12 rears will the height be different from front to rear from my stock 25-8-12 and 25-10-12 wont the front be taller then rears with my stock rims??
If your fronts are currently 25" tires, then putting 27" tires on it will definitely bring the front end up.
What machine are these going on? Is it 4x4?
Im looking at maxxis 27-9-12 fronts and 27-10-12 rears will the height be different from front to rear from my stock 25-8-12 and 27-10-12 wont the front be taller then rears with my stock rims??
Why are you running 25 on front and 27 on rear? I hope that's a typo. If not... You are in for a diff rebuild in the near future
Why are you running 25 on front and 27 on rear? I hope that's a typo. If not... You are in for a diff rebuild in the near im running 25 8 12 in front and 25 10 12 in rear want to run 27 9 12 in front and 27 10 12 in back my rims are. 6 wide in front and 7 in back. I also have another set of rims that are 6 wide fronts and 7.5 rear could i run maybe 7 inch rims in front and 7.5 in rear to make up for tire width ?
