Just remember for $10 dollars and 1.5 mm of shim’s installed in your cvt will help you get back anything you loose in heavier tire’s.
Just remember for $10 dollars and 1.5 mm of shim’s installed in your cvt will help you get back anything you loose in heavier tire’s.I’m looking at the weight of aftermarket tires and they’re much heavier than I expected. Sedona has the only light weight tires that I like. Now I’m looking for somewhere to source them mounted...
Maxxis zillas are not a heavy tire.that's one of the reasons I chose them.I’m looking at the weight of aftermarket tires and they’re much heavier than I expected. Sedona has the only light weight tires that I like. Now I’m looking for somewhere to source them mounted...
This is why I did 27” with stock SE 12” rims. It maximized the amount of rubber between me and the rocks, and isn’t too heavy, and is drivable without mods. But the mods made it more fun - lol! Ground clearance is pretty good with a 27” too, I think 12.5. Stiffen up the shock to maintain clearance in rough terrain, and go soft on air pressure for a tolerable ride.@Kokopelli
So, @Vincent steered me back to 12" wheels from 14s and I really appreciate what he did as 12" wheels will give you far greater tire volume in 25"-27" tire diameter size. Problem becomes for you when you are looking at something like those 28" Coyotes, which I agree look like incredible tires... assuming the Coyotes. I'd really like to also try out the Maxxis Carnivores but those only come in 28" at 14" wheels or bigger. Just make sure you are also looking at tire/wheel weights because that rotational weight can really rob your HP where you may need CVT mods to gain back low end torque. Something that Kodiak/Grizzly riders need to also be paying attention to because we don't have massive, unreliable HP/torque.
Shims...I like the Tusk Terrabite, but they are heavy. Therein lies my dilemma.
Time for some clutch mods!I got the Kodiak out today. I believe the size, weight, and tread will work for me. They really calmed the quad down. Seems it has the wah-wahs a little, but it's cold and I probably didn't ride long enough for them to warm up. I think I'll air them up to 25lbs for a couple of days and then drop to 5psi for the initial setting. I may need to balance them, but it felt more like a flat spot.
I could definitely tell I have lost some speed with a corresponding shift in the power curve.
The original runup to the power curve is completely gone. It starts out with a good pull and stayed there until I backed off at 40mph I suppose. I also installed the barker slip-on muffler, topless airbox and EHS controller..
I guess a lot depends on one's background and experiences. I've been involved with custom machines all my life as well as a career in research engineering. I'm kinda a fabricator in several fieldsAh yes.. the never ending quest to get our rides 'Spot On ' I have been very happy with the tire upgrades and stayed with the stock sizes. However increasing the front track by 3 inches has been a great improvement. I must admit that I am afraid of altering the engineering excellence built into the bike and adversely affecting reliability. Guess I am showing my age. LOL
My factory 12x6" alloy wheels are 5 lbs a piece.The M12s are 13lbs
Yup, the bikes have done off the lightest wheels I've ever seen, yet still super strong.My factory 12x6" alloy wheels are 5 lbs a piece.
That's 32 lbs in extra rotating mass without even counting the extra weight of heavier 6 ply tires vs stockers
