1 - 3 of 3 Posts
On my last ride at Windrock, I came home and noticed something odd. The left side panel over the exhaust had popped out, and it has a smoked area, like the exhaust had lit it up. I have a couple pics to see the area that has turned color. When I removed it, I see an outline of a box on the back. Does anyone know if this panel is supposed to have 1 or 2 rubber blocks that ride against the frame? Any suggestions on the hot spot? I’m going to look for an exhaust leak, but it seems like it is just from temperature.
Sleeve Wood Shade Plant Grass
Road surface Asphalt Automotive exterior Tints and shades Hood
Hood Automotive tire Blue Azure Road surface
2022 Kodiak 700 SE
Mine has two blocks. The one you are missing goes between the exhaust and the plastic. The missing block is a lot thinner, maybe 1/2" or so.
And I just lined the entire back of the panel with reflective heat tape… now to try getting the block replaced.
1 - 3 of 3 Posts
