1 - 11 of 11 Posts
i seem to recall this question came up in the past..I remember my radiator always kicked on when i first turned the key over but now it suddenly isnt...even after a few minutes of running I cant get it it to kick in...I'm trying to determine if my engine just isnt getting hot enough for it to kick in or ifI'm having a problem with it
Yea. Ive seen alot of people talk about this. I believe it comes on at about 200 degrees just to maintain that constant temperature. Its not overheating when the fan comes on. But it does take a little while
does it always kick on automatically when you first turn the key in though?? i seem to recall mine always kicked on just by turning the key but never actually starting the engine...suddenly its not doing that anymore
Mine never has kicked on when I first turn the key on unless the temperature is way up there.
I have a actual coolant temperature gauge and the fans won't kick on until around 204 degrees F then they kick off at around 194
My fan comes on when my temp gauge reads 201 degrees which is close enough to 200 :)
My fan only comes on when hot.This maybe a stupid question but,are you sure it was the fan and not the fuel pump?
Reactions: Madmax
To me it sounds like a fan, i am not a mechanic but next time on my machine ill get it too 200 degrees and see if it is infact that.
good question..i just stopped by the dealer and they thought it was a fuel injection pump..i hinestly dont know but i sewar i used to hear a humming sound (like a fan) when i first turned the key over ..nobody else hears that?
It just may be the fuel pump under the seat.
It will come on for a couple of seconds until the fuel line is pressurized and it does sound a little like a fan.
Sounds like the fuel pump cycling. Perfectly normal
Reactions: Madmax
1 - 11 of 11 Posts
