Do you have a diff lock light on your bike and is the diff lock symbol there at anytime during cycling the display? I had another customer ask this over the phone. If Yamaha actually wired that circuit and if it's the same exact display as the Grizzly then it's possible that it would work but typically the 1 wire indicator on the diff is only set up to show in two positions from the factory (2wd and 4wd). In this case, with the Grabber kit, the 4wd indicator on the digital display will come on when the bike is in diff lock. There is an indicator on the lever itself to let you know 2wd or 4wd.
