Has anyone installed 20 gram clutch weights, I'm not sure if I want to go full grizzly. I don't want it too jerky and although I like the quiet low rpm I want to squeeze some more power out of it. Any suggestions?
I'm not really wanting to shim or anything, I'm just wondering what the difference will be if I run just lighter clutch weights. I just feel like it revs too low until I really lay on the throttle at low speeds.I did not want to go full Grizzly so went in the middle. I'm running EPI 22gram (approx. 24g with the covers) and wet clutch slug kit and 1.5mm shims. I don't have many miles on this set up yet but so far I'm very happy with it. Great improvement over stock.
Thanks, I'll probably end up with 21 gram weights.The lighter the weights the more RPM's it takes to in gage them. So basically you are starting to move at a higher RPM and higher up in the engines power band. 20 - 24grams should get you where you want to be.
