1 - 13 of 13 Posts
I found oil laying in my air cleaner box, about a 1/2 inch in the lower part of the box. It's been running fine. I was wondering what would cause this to happen. appreciate the help!
Just clean it up and then watch your oil level or check the intake box before you ride it.
With a new engine it quite possibly is just from over oiling the filter, but you never know.
I looked at mine yesterday and with buying it used you would of thought that either the previous owner or dealer would of checked it out but they didn't. There was about 2 tablespoons of what appeared to be gear lube. Granted it was cool here around 20 degrees but if it was actual oil you would think that it would be a lot thinner. But the stuff that I cleaned out of the housing was like what I would use to grease the bearings with.
I read a couple of posts that folks are using a thicker grease to help seal the airbox. I would assume that is what you are seeing.
Discussion Starter · #12 ·
I rinsed my filter out to get the engine oil and excess filter oil out of it. The dirt came out but there was still a good bit of oil left in the filter after it was rinsed. Covered my hands twice with oil and rubbed it in, wasn't sure how much you should actually put on it.
On a foam filter you want a good bit of oil on them. I usually put quite a bit on them and then stand them on their end on a piece of cardboard and let them drain for a day before I put them back on. That way if there is any excess oil it will make its way off of the foam filter.
Reactions: Link
1 - 13 of 13 Posts
