This is my poor mans ehs racing mod copy, I knew I wanted to use the bell end of the factory unit . So I cut out the middle and adjusted it so the 2 half’s would fit in the air box. Measured the inside diameter of the intake and found that a 2 inch exhaust pipe would work perfect to bridge the gap and be thin enough and stiff enough to give support and not restrict air . I cut a 2.5 inch piece off the pipe, smoothed the ends and superglued the bell end on to it .
I install the bell side into the air box ( and as you can see it’s very close to a perfect fit in my adapter ) then the throttle body side of the of the intake is slid onto the air box and is slid over the exhaust pipe connector simultaneously. The exhaust pipe is a very tight fit in the factory hose a little lube is needed to get it pushed on all the way . I haven't installed the air box yet but will let you guys know what I think when I do get it together.
