I can go more into the installation later but wanted to share a picture of the final product.
Warn Provantage 60 inch blade PN: 78960
Warn Provantage Front mount: PN: 95745
Warn Plow Base for use with front plow mounting kits. PN: 92100
KFI 3000lb winch: A3000 ATV Series
The KFI winch works for the Warn plow mounting system. I did not need to alter any of the setup.
Warn instructions are maddening but made it through in a few hours. If I had to do it again probably take about an hour or so to complete.
Just so it is stated. If you purchase from Warn make sure you follow their configuration path. If you buy a Provantage mount buy a Provantage blade. The Standard and the Provantage cannot be mixed. I had a standard blade and the Provantage mount is about an inch and half to wide for the mounting brackets on the plow.
