Make sure to get some loctite, should help in preventing the vibrations from doing anything.I picked up the aux light. Looks to be decent quality except for the mounts.
I stripped two of the bolt holes in the aluminum spacer block, using a hand nut driver, with very little applied force. I couldnt believe it!
My plan is to drill through and use stainless steel bolts and locknuts.
Also debating on rack placement vs handlebar placement.
How are you finding the weight of the plow to be? Are you really feeling it when moving around or what?Thanks Robval for the inspiration. I finally made it happen. (Only blew one fuse!)
Its not bad. Just have to get used to it with the soft suspension.How are you finding the weight of the plow to be? Are you really feeling it when moving around or what?Thanks Robval for the inspiration. I finally made it happen. (Only blew one fuse!)
