Anyone have any experience with this?
Water pump seal went bad on my 2016 Yamaha Kodiak 700EPS - YFM700FWBD 2SM3
Bought a Moose racing replacement seal. The Moose Racing seal is different to the Yamaha seal it is meant to replace.
The Yamaha seal is a multi part press fit assembly with spring loaded ceramic surfaces to make the seal.
The Moose Racing item is only part of this assembly and comes in two pieces. It is missing the pressed in outer seal retaining cup, the bearing shaft for the pump impeller shaft and the pressed on retaining collar which holds it all together under spring pressure.
I have tried to recover the missing parts from my scrap seal but they do not want do drive out. The parts are small and will be destroyed by in the process of removing them I think. Previous seals I have bought have been complete assemblies.
Does the Yamaha part come complete without needing further detailed asembly? See photos. Yamaha seal is on the right.
SEAL, MECHANICAL - Moose Racing - 0935-0852
SEAL, MECHANICAL - Yamaha - 2MBE243800
Thanks, Ed.
Thanks, Ed.
