1 - 9 of 9 Posts
I have what I hope is a simple question. I bought a 2016 Kodiak EPS SE and would like better tires.
My question is do I use the stock SE aluminum wheels (are the good or soft and flimsy?) and put a taller 25" like a bighorn original on or will a 26" fit on stock wheels or are the stock wheels garbage and should I just buy 26" on a new wheel (does 26" fit without a lift kit or spacers?).
If I should buy a 26" bighorn or similar tire that runs large and fits without a lift or spacers, what wheelnl do you recommend? I am looking for a light yet strong aluminum wheel to keep unsprung weight down and offset the heavier tires.
So do I keep the stock wheels and put a taller 25 on, keep the stock wheels and put a 26 on if it fits or so I get new wheels with a 26 if it fits.
Thanks
just depends what you want. if the rims are 12in then most tires will fit that go on a 12 inche rim. me personally i would keep them wheels and tires mounted and just buy a new set of wheels and tires just so i have to sets if something happened and you had to wait on a tire you got a spare set
Well I called discount tire and rockymountain and they both said the stock wheel is good and there is not need to buy an aftermarket one. I ordered a set of Bearclaw HTR in 26-9-12, 26-11-12.
Just need to figure clutching out now.
Thanks
No pictures????? :wink2::crying::nerd:
1 - 9 of 9 Posts
