Am considering replacing stock tires on 2020 Kodiac 700. Down to. Kenda bearclaw HTR or mastodon HT in a 25 x 10/12 at all 4 corners vs 26 x 10/12. Are the heights of these accurate. I will pull the rear tires off the 450 and put them on the front to see if this changes the turning radius. Would you expect 10 inch wide tires on the front to fit fine as I would expect. Can you put 11 in wide tires on the stock rims for the 25 inch x 10/ 12 rims. Thanks for any suggestions / experience with these combinations. Red.
