I have a Kodiak 450 2020 and noticed I do not have this brace between my shocks - was this a standard issue or some kind of add-on. What exactly is it supposed to help with? Thanks
Automotive tire Automotive lighting Helmet Bumper Automotive exterior
Looks aftermarket.
Neither the repair manual for the 450 or Partzilla shows that brace.
That is a highlighter lift kit. It re-positions the shock mount about 1.5” lower, effectively giving you a lift. It also works your cv knuckles a little harder
JD864 beat me to it ..
Light Product Font Gadget Screenshot
Reactions: JD864 and JimP
Thanks - I am looking at a second Kodiak for the wife and noticed this on it. I can see where there would be a little additional wear and in our case, it is not really needed. I figure if we get it I will pull it off and return it back to stock. The ATV only has 500 miles so I'm not too worried about the wear. I noticed the owner had a 2up box on the rear so I guess he was trying to make up some clearance that was lost with a 2nd person on board.
I was thinking it was a rear shock frame brace so thanks for the info.
