I decided I would put on a winch as sometimes I like to just go out riding, but worry if I get stuck and have no one to help get me out. So with that I ordered a Winch Plate/Mount (fits both the 2016 Kodiak and Grizzly 700's) through KFI (part #101275) just as good as Yamaha if not better at half the cost at $47 with free shipping. The Winch I ordered through E Bay (3000 pound Extreme Bad A$$), this winch comes with alot of accessories. It came stock with the winch, steel cable, roller fairlead, hook, handlebar controls, all power cables, and solenoid. It also comes with 3/16 synthetic winch rope (rated at 7000 pounds), aluminum hawse fairlead, and rubber winch line guard. The one thing I really liked about the winch mount was that it has a spot to mount the winch solenoid directly to it. I did opt for the Synthetic Rope, Hawse Fairlead rather that steel cable and rollers (save on weight). I did cut and fit all winch power cables (as I do not like a bunch of excess wire hanging around) and I installed heavier connectors along with heat shrink for that clean custom look. Also with the handlebar controller I found out it looked clean mounted right to the upper brake handle bolt (rather then using all the mounting hardware that came with, my preference only). Also while I did the winch install I went one step further and removed my front rack (my front rack has my Raider Storage Box attached to it, along with my 12 inch Auxbeam Led Light Bar attached to the front of my box, and my Snorkels are also mounted off the rear of the box. So I installed a quick release connector on the wire to the Light Bar. (Now I can loosen up the 3 hose clamps to the Snorkels, unplug the Light Bar, remove the 6 bolts that hold on the front rack and lift everything off as 1 complete unit) giving me easy access to the electroics and battery compartment under the rack. Here are a few pics of my install.
:nerd:
:nerd:
