1 - 3 of 3 Posts
Okay so I got my new axle's with cv joints in from hex auto parts .
Now take the out cv joint (stock) off was easy.Now I am taking off the inner cv joints that are in the block. I can't figure out how to get the axle out, I pulled the whole cv joint out of the front block on both sides. Now its just getting the axle out and putting my new 1's in.. front and back.
What should I do ? Any suggestions ?
Thank you in advance.
Are you talking about the piece that goes into the differential?
If you are there is usually just a circle spring clip that holds it into the diff and just pulling on it or using a slide hammer should pop it right out.
Just so you know I haven't taken one apart on a 2015+ so I could be wrong.
1 - 3 of 3 Posts
