I can back you up on that sammich comment. I tossed a cold McDonald's cheeseburger, still wrap up age in paper bag, we stopped for lunch about 3hrs into our trip, guys fired up the little camp stove, and I suddenly remembered that burger, when I pulled it out, it was warm like it just came from the drivethru window, cheese was a bit melty too....I have read somewhere that people have install heat tape to the underside of the plastic. Maybe try header wrap on exhaust. I also have EHS tuner and AIS deleted and some other stuff. Mine does not seem to get as hot after the tuner as it did before I installed it. Hope this helps. Good luck. It will melt your grilled cheese sandwich if you keep it in the glove box is an upside in winter.
Yes you can do it on a stock air box and it will help with deceleration popping and couldn't hurt the heat issue. Just remove inner fender and tire and block the hose.Anyone block off the AIS Without doing the air filter mod? And is this ok to do?
Yes and yes . I ran mine and the wife’s for a year with just the AIS blocked off stock filter.Anyone block off the AIS Without doing the air filter mod? And is this ok to do?
It greatly improved the poping on deceleration on my 17 and wife’s 16. You are not going to hurt a thing by blocking the hose.Interesting thing is according to my service manual description of the ais system it says the Reed valve only opens when idling and low coolant temps.
No way the 2 are connected. It's air into the exhaust, no way it can effect oil pressureI have had some reservations on blocking the AIS because I have never felt my Kodiak ran hot. My spark plug is always the perfect golden brown and clean when I check it. So thought I would try it anyway and after I plugged off the AIS today I went for a ride and after a half mile I had huge cloud of white smoke surrounding me and Kodiak. Quickly hit kill switch and checked dipstick because of strong oil smell. Dipstick was out of the spout, have it teathered So not lost, put back in and drove slowly back to barn and spent 2 hours cleaning the mess and added 12oz of oil to top it back off. Thinking I may have not put the dipstick back in all the way when I checked it this morning, I went for another ride and it happened again dipstick pushed up and out againI was keeping an eye on it so didn’t loose as much oil. So tomorrow I will be unplugging the AIS and putting back to normal. It must be increasing my oil pressure, it’s the only thing I can think of that could be pushing the dipstick out. I have never read of anyone having this problem from blocking the AIS.
I'm wondering if it's a head gasket. I'm not sure if there is a pcv valve or such on these engines but it's definitely building crank case pressure to blow the stick out. I know a failed head gasket on an air cooled engine with ohv's can pressurize the crank case but I'm not sure on a liquid cooled engine. I just replaced the head gasket on my lawn tractor this week.No way the 2 are connected. It's air into the exhaust, no way it can effect oil pressure
I had a blocked vent line from my oil tank on a Harley and it shot the dip stick out and blasted my leg with hot oil. I really doubt the AIS delete is responsible but It has shown you that the crank case vent might be blocked. I'm very interested in your findings. Please keep us posted as to the results. Best of luck.I have had some reservations on blocking the AIS because I have never felt my Kodiak ran hot. My spark plug is always the perfect golden brown and clean when I check it. So thought I would try it anyway and after I plugged off the AIS today I went for a ride and after a half mile I had huge cloud of white smoke surrounding me and Kodiak. Quickly hit kill switch and checked dipstick because of strong oil smell. Dipstick was out of the spout, have it teathered So not lost, put back in and drove slowly back to barn and spent 2 hours cleaning the mess and added 12oz of oil to top it back off. Thinking I may have not put the dipstick back in all the way when I checked it this morning, I went for another ride and it happened again dipstick pushed up and out again 😡 I was keeping an eye on it so didn’t loose as much oil. So tomorrow I will be unplugging the AIS and putting back to normal. It must be increasing my oil pressure, it’s the only thing I can think of that could be pushing the dipstick out. I have never read of anyone having this problem from blocking the AIS.
Yup that's the one I blocked. No issues until I did this, maybe I pinched something else but will be taking it apart this afternoon to look.On the right side of the air box( sitting on the atv ) is the breather hose for the engine. Might want to check it out, I just can’t see how blocking off the AIS could cause the oil filter dip stick to pop out
Ok wait, so if your sitting on the atv the hose you blocked off is going to the right side of the air box? If you did it’s the wrong one. you want to block off the one on the left side, the side your shifter is on.Yup that's the one I blocked. No issues until I did this, maybe I pinched something else but will be taking it apart this afternoon to look.
