So, I’ve got a tire that has lost air twice in a couple of hours. I did the soapy water spray and went as far as putting the tire in a tub full of water...no leaks anywhere. Any other ideas to find the leak?
How many psi of air did you have in the tire when you checked it? You may have to increase the psi quite a bit to get it to where you can see a good stream of bubbles.
Also check the air valve.
X2 Did you check the valve for leaks?
If your still running stock tires, get rid of that garbage.....
Or put a couple bottles of Tire Slime into them and forget it.
I have never had any problems with the stock tires holding air as long as I didn't put a stick through them
