1 - 18 of 18 Posts
Read, your owners manual. It will give you a lot of information about what oil to use and its viscosity.
Most will just use YamaLube
Others will use a full synthetic
I am using Valvoline ATV oil.
Owners manual will keep you from using some strange oils that may not be ideal. Before some fella tells you to throw some wal mart oil in it
Im newish to atvs, my owners manual mentioned yamalube...
Ran plain 10w40 Yamalube for the last 5500 miles with great results even in brutally -25c cold starts.
Just switched to Atv / Utv Amsoil full synthetic. My bike has 8000 miles.
If you are sure it's broken in, my recommendation is Shell rotella T6 full synthetic 5w40.
This is exactly what I run in my 700 kodiak now that it's broken in. Bought a 5gal pail.... Should be good for a few changes. Lol
Do you consider it broken in by the first oil change or the second? I know it's officially broken in after 800 miles but should Yamalube be used for one more round and then use synthetic at 1600 miles? That's what I was planning on doing.
I used Yamalube on the first oil change, I'll be using Rotella T6 from here.
I waited till I had over 400 miles on my Kodiak before switching to Amsoil full synthetic ATV-UTV 10w-40. I figured it was broke in by then. It had 2 oil changes of Yamalube prior to that.
according to the manual, break in period is 20 hours or 320km (200miles) whichever comes first. Ideally , that's when first change should be done.
my manual states this, as did the service department at my Yamaha dealership.
Again this is very interesting, I now think that the manufacturers use additives or something to insure proper break in. After reading and researching, I am not sure they use a true synthetic on new engines.
Break in oil can be conventional or synthetic. It's the additives used that determine how the oil works.
1 - 18 of 18 Posts
