1 - 11 of 11 Posts
I have read so much info on improving engine operation, that I am curious if any of you have bad results or recommendations. I also know there are some info on this, but I could not find it, and I am hoping for some up to date info, as you are all a great resource for good info. Also, does adding this device to my new machine, void the warranty?
I can't help you much on a tuner but as far as voiding the warranty I would say that it would.
Your machine came with a specific factory tuning and any alteration to this tuning will void the warranty. I know on most vehicles that have a computer that sets the tuning they have a program within it that will tell them if anything has been changed or altered. I am not sure on the Kodiak but.........
Well I have a long extended warranty so I guess I will hold off. I am curious if you feel that a tuner is a good thing or overstated. It does not matter how cold it is outside, when I shut this machine down it smells hot and the radiator fan runs even when it is 20 degrees. I am not concerned about the running quality, it is fine, I am looking for engine longevity.
Thanks for the input!
The nice thing about a fuel tuner is you could always take it off before going in if you ever have something going on.
I thought that they couldn't void the warranty unless they could prove the the item you added caused the issue.
Anyway my warranty was up after 6 months, and I never gave it more than a couple thoughts...where to get a tuner, and how long would it take me to install it.
According the the laws here in the US they shouldn't be able to void it if the tuner didn't cause the problem. However if they suspect one and see that the tuning parimiters have been changed they can do just about anything that they want to and it is up to you to fight them. And like all big companies their pockets are a lot deeper than ours if it goes to court.
On the temperature and the fans running even when it is cold out, you need a actual temperature gauge to tell you just how hot your machine is getting. On my aftermarket gauge set up it has a actual temperature gauge with the sensor installed in the radiator hose. I have found that even when running in cold temperatures that the max temperature that I have seen in 206 F when the thermostat opens and then it will stay between 194 F and 206 F.
I never have watched to see just when the fans kick on.
I fully believe that these engines, as with many engines are set to run for maximum EPA testing. As some of you may know, in recent history and may still be the case, the California EPA had extra stringent requirements, and many engines could not be sold there. Lean engines burn up eventually, I wish I knew if that lean condition takes a year or a month off the life of the engine. I have a laser temp reader and I will take some readings on the engine and hoses and see what I find.
Thanks for the input and info!
the fuel tuners are piggy back, they do not alter the fuel map in the ecm, they read data and send the new signal to the injector telling it how much fuel. no altering the ecm so nothing could be detected to void warrenty.
it states in the owners manual that the fans will come on once the atv reaches operating temperature
just because they come on doesn't mean it's running hot, it's at proper temp and the fans are ensuring it stays in that range
The fan runs after you shut the key off? That is not right.
nobody said anything about fans on after key off, he said even when its 20 degrees outside. you need to read it and see he missed a comma in his sentence.
1 - 11 of 11 Posts
