Brand new 2016 kodiak owner. Bike has about 9 hours on it been having it for 5 months. Rats chewed through the LEAN ANGLE SENSOR coupler wires. My local dealerships warranty doesnt cover rat damage and they wanted $550 just for a new wiring harness... Thiefs. Anyways my buddy whos a mechanic and i reconnected the wires thinking it would do the job... It didnt! Bike still wont start. The feul pump is getting only 2 volts through the power wire to the pump. Which ties in to the angle sensor. The lean angle sensor stops the bike if it tips over. Question is does anyone know how to check for codes on the 2016 base model kodiak without the eps pod. The lean angle sensor is connected correctly so my buddy was thinking its possible a code needs to be cleared to send a signle from angle sensor to pump. That may not be the case but its worth a try. We just dont know how to check it on the new kodiak. Older models used to use a paperclip and watching the light blink. Is it possibly the same on new models
