1 - 11 of 11 Posts
I haven't replaced one but to pull the axle you need to pull the A arm off. But it isn't too bad of a job, it just takes time. I would guess that you are looking at 4 hours shop time at the minimum.
If you go to 501 Parts web site and look at their how too's on installing their locking diff kit you will see what needs to be done to get the axle out.
https://youtu.be/tlE4-R_zGcg
I'm taking it for granted that it is on the front.
But the rear would be about the same.
I've replaced one of my rear outer boots before. It's a dirty job and it takes a bit of patients but it can be done. I simply YouTube it. Look under Grizzly or Kodiak as the steps are all the same.
Make sure therouly clean out all the old contaminated grease and repack with fresh.
The front axles are trickier to remove as you need to separate 3 ball joints per side.
I was quoted anywhere from 1.5 -2 hours labor plus parts. Watched many videos on how to do it. I like Partzilla videos the best. Ended up pulling the axle (front right) and taking it to closest dealer. Pulling it was pretty straight forward. The dealer is going to replace the boot for 40 dollars, that's labor and boot. I can live with that.
Happy things things are working out for ya.
Kinda frustrating that the dealers lay off most of their mechanics around here in the winter. Will be 3-4 days to replace a boot on an axle that's pulled from the machine. Still, gives me time for other maintenance oil change etc.
I had both fronts get torn. One of my axles got damaged and it was cheap to buy complete set of aftermarket half shafts off ebay so I used one of the new axles, and I also bought a CV boot and grease for the other one and saved one of the new axles as a spare.
The front axle removal is one of the easiest I've seen, and you don't need to remove much at all.
Break the lugs loose, jack it up, take off the tire, remove the hub nut with air, disconnect the lower ball joint and pop it loose, turn and then lift the upper arm by hand, bump the end of the axle with a clean rubber or dead blow hammer, then you can pull the axle out of the hub, then it just pops out of the transaxle. I used a couple of good sized flat screw drivers or pry bars to pop it out of the transaxle (one on each side to spread the load evenly).
Going back in is the reverse with a few moderate blows to the axle to drive it into the transaxle. Oil the tip of the end that goes into the transaxle, and keep the axle straight as possible when driving it in. I recommend a cheap good sized deadblow from Harbor freight.
1 - 11 of 11 Posts
