1 - 3 of 3 Posts
I recently purchased a Kodiak 450 and noted that the coolant level in the reservoir was below the full line. I contacted the dealer I purchased it from and he said it is normal for the coolant level to be between low and full. Does that sound right to you? The engine was cool.
I also noted that the tank filler is in a rather precarious spot. Is there a way to add coolant without disassembling half the wheeler?
Any suggestions would be greatly appreciated. Thanks!
Go down to your local Walmart and pick up a funnel with a long tube attached, it will make topping the fluids off a lot easier.
I actually need to pick up 3 or 4 more just to have on hand since the one that I had I used for the fluid change that I did last month.
Good idea, I'll give that a try. Thanks for the info.
1 - 3 of 3 Posts
