I would flush out the green coolant first.
There are coolants that are not compatible with each other and unless you know for sure a flush is the way to go.
For the green I would of just went with some Prestone or other green coolant.
From what I read after posting is that it is eythel glycol based which is the same as the green so it should be compatible.
I would still drain the system and then just put the blue in and keep it just one color.
My 2016 has green in it also and I plan on just using some Prestone that I have in a couple of years when I change it out.
