You can stick a screwdriver into the hole to see if there is a gear that you might hit.
You can also cut the new bolt down, I would see if I could find a nut for it to put onto the bolt that you can take off so that you don't screw up the threads too bad.
A dealer may or may not charge you for a repair. There was someone on here a couple of years ago that stripped out a drain or fill bolt and took it to the dealer. The dealer took care of it without charging him. You just never know.
