It is the piece of junk switch. You will also find that the starter override doesn't work either.
The switch is located on the rear diff on the left side. You can grab the spring that is attached to it and pop it out and work it back and forth to get it to work.
On mine it will work for a while before I have to play with it again. I am going to pull it apart this summer and see if I can fix it or just replace it. A replacement is around $26 if I remember right
