I'm looking for help with a problem.
Ten days ago, I took my 2016 700EPS into the dealer for it's first yearly check up ( oil change with filter, greased where needed and cleaned air filter). Up to this time, it worked perfectly, after the visit to the shop, it sat several days then when I started it, there was a lot of blue smoke and the tail pipe was wet/black.
I took it back to the dealer and the mechanic looked it over, cleaned the tailpipe and told me there was a device in front of the cylinder that was connected to emissions. The problem was that the motor was cold and not burning this away, but once it got warm enough it would stop. It did. I brought it home and went for a 10 mile easy ride with no issues. Today (six days later), I started it and filled the garage with blue smoke. I took it out and let it idle and revved it a bit and it seemed to stop with the blue smoke.
I'm taking it back to the dealer first of the week, as the shop part is closed today.
Can anyone suggest the questions I should ask?
Suggest what to look for.
I'm not much of a mechanic so depend of buying the service, so any help is much appreciated.
