1 - 3 of 3 Posts
Does anyone know if the grizzly axles will fit the Kodiak? I'm having a hard time finding axles for the Kodiak but when I search for grizzly axles, a lot more options come up.
I can't help on the fit but you could always go to a on line parts dealer and compare the part numbers and see if they are the same or different from the Grizzly to the Kodiak. Then if they are the same they should fit if different I would keep on looking for the Kodiak's.
IIRC the Grizzly axles are longer. However based on model year of the machines some Grizz axle may fit the 2016 Kodiak, I don't know.
You can go to bikebandit.com and pull up your parts diagram . When you click on a particular part number the fitment tab will give you a list of machines that part is on.
1 - 3 of 3 Posts
