In the interest of adding as much stability to the IFS for extreme side hill stability has anybody mounted 2+5 offset 12 inch rims with 26 inch Big Horns OG tires?
The Kodiak has plenty of ground clearance for me, just needs a stiffer, more aggressive tire. Adding stability with offset just makes sense to me, if it will still fit.
10179
This is a pic of ITP deltas in the offset you asked about. Rears had too much poke and fronts didn’t clear the calipers. Had to go 4-3 offset. Actually like it better too. If you are dead set on 5-2, you’ll need a small spacer for the fronts
