Just joined to let you all know that there is a really easy fix for stupid foam filter dusting your engine. Napa gold 6449 air filter and a 1 1/2 pvc coupler. Put the coupler inside filter and slips inside breather tube in factory air box. 2016 Kodiak 700. Put air box lid on your done. 70 cfm filter. Performance seems fine. I have dusted to many engine with foam. Just thought I would let you all know this simple fix.
Thanks for the pictures! How did you get the 1-1/2" coupler down in to the filter? Were you able to force it in, or did you cut some of the rubber in the filter?
Miss information on coupler size it should be a
1 1/4 pvc coupler. Sorry for that. 1 1/2 pvc pipe should work. Thought I had a different coupler. Any how hope that clears things up.
It looks like you could put your factory foam filter over the paper filter but 70 cfm paper filter is border line for air flow. I don't think it's necessary. Just run paper alone. Paper will plug
quickly in extreme environments. Might change paper filter every oil change if needed.
I only have a hundred miles with this set up. So I'm experimenting, others may have more input. I just don't want to dust another engine.
Don't have to do anything. It slips in the intake and even fits in the filter holder inside. I put alittle grease round the snout of the filter just for extra measures. Probably don't even need that.
I assume by sitting higher up and raising the center of gravity, the ATV will be more tippy. Maybe some adjustable shocks will give you a bit more height without the negatives?
Thanks Magard for sharing your findings and the pictures!
Did you have any problems with the OEM filter setup that prompted the search for a replacement filter?
I manage a 28000 acre cattle ranch. There is a lot of dust. If I run foam filter I can't clean them enough to keep from dusting engines. It's just something I've learned the hard way. Foam filters are a joke, and I hate seeing people loose engines because of them. If I was racing, and planing on a new top end every race, foam would be the way to go. That's not my style of riding so paper filter is what I use.
Maybe alittle. It seemed alittle lean so I adjusted my throttle position to a more comfortable position which limited my wide open throttle some. I still have way more power than I need.
The lean mixture might just be the way they are from reading other posts. I converted mine to paper filter on the first day I got it.
Intake end is rubber. Fits real good. I put alittle grease around seal area just for extra measure. You just have to try it you won't believe how good it works.
Hey Magard!
Read the air filter modification you did. Have a 2016 Griz. I did the same but, used a ACE Hardware "couple" Part # 43107 (1.965") vs (1.900") that the PVC pipe is. For your info also, Wix air filter P/N WA10011 has a radial seal diameter of 1.800" has a Length of: 6.594" Top & Bottom "OD" of 4.880 inch, and has a CFM air flow of 140. Got this from them direct. Double the air flow of the NAPA filter 6449. K&N makes a grease for sealing radial air type air filters. P/N 99-0704. I am not a member of this forum, but my email is: I do not know if you will get this info.
Have you tried the filter. It looks like it has potential.
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Yamaha Kodiak 700 Forum
27.3K posts
3.3K members
Since 2015
A forum community dedicated to Yamaha Kodiak 700 ATV owners and enthusiasts. Come join the discussion about reviews, trail riding, performance, modifications, troubleshooting, maintenance, classifieds, and more!
