Will these fit on stock rims and not rub on bike without lift kit or spacers. If so what rims and offset are recommended.
No shaking here. The aggressive tires are a bit rough below 5 km but no issues otherwise.When you put on your larger tires did you notice any shaking up front?
I am running the stock rims. Not sure of the offset. I opted out of replacing them because aftermarket rims are heavier.What is the offset on your rims?
i'm having that issue right now . put on 26" tires similar to bear claw htr pattern.When you put on your larger tires did you notice any shaking up front?
I'm guessing you want to run the same size tires at all four corners?Will these fit on stock rims and not rub on bike without lift kit or spacers. If so what rims and offset are recommended.
it's tread life, not thread....tires, not sewing. sorry this is just a pet peeve of mine .I'm guessing you want to run the same size tires at all four corners?
If so they will fit your stock rims without issues, but the tire profile will be different because your front rims are skinnier then your rears. 6" vs 7.5"...
Best to get 4 aftermarket rims as to maintain the same profile and you can then have the added bonus of doing regular tire rotations. Thus getting the max thread life out of all four tires.
lol its not a grammar issue, its just saying a word wrong. lolWell it looks like the grammar police have shown up lol.
Why do you keep replying to old threads?View attachment 10316 14” Vipers with 27” Bearclaws View attachment 10316
