1 - 19 of 19 Posts
Well after about 50 easy miles the radiator in my 2020 Kodiak started to leak. The plastic expansion tanks crimped onto the side if the radiator, lower left corner has come loose. You can push it up and watch it leak, anyone have any issues? Going back to the dealership Wednesday, really starting to regret leaving Suzuki
Stuff happens, haven’t seen anyone with a factory leak like that. I’ll have to look at mine again as I swear my end caps are aluminum on my 19’
65 miles on my 2020 and I am losing coolant. I have no obvious leaks ie no coolant on thefloor. When you say left hand side are you looking from the rear or from the front?
They all come with the coolant level in the recovery tank at the low level mark. Also may have been some air in the system. Have you added coolant to the recovery tank, and if so, is the level dropping.
My 2019 was at the low mark when I got it. I filled the recovery tank to the high mark. Still at the same level now with 200 miles on it.
The new Kodiak 700 does not cover the radiator properly. So, if you go fast, you end up with holes in the rad since flying rocks from the wheels can fly into the exposed rad. I was told to take plastic from old Honda quads and place it behind the wheel and protect the rad.
On the top of the radiator(2018 model) there are two rubber grommets that hold the radiator in. And the bottom has a couple bolts.
Ive seen the grommets allow the top of the radiator to come out at the top. And results in the radiator getting jostled around on the bottom bolts only, until it springs a leak.
My friends 2016 had this problem.
I took 2 small wooden blocks and shoved into the gap that allows it to fall out of the top. Not had any issues with leaking radiators since.
He wrecked his radiator 2 times before I noticed what was happening
I'll have to look at mine and see how it looks when I do my maintenance on it next week.
With almost 4 years on it and quite a bit of riding I haven't noticed any problems with it
I have a 2006 gulfsteam enduro C5500. I am on my third radiator. Each winter it starts to drip from the drivers side support. This happened when I was in Southern California and now Georgia.
Each time we replaced it with a factory radiator.
Has anyone else seen this?
Looks like this thread has 2 trolls in it so far, one Honda fan and this last one asking about an Enduro.
Reactions: MarshMaster
1 - 19 of 19 Posts
