Hello,
need some help identifying plugs under my final drive 2020 Kodiak EPS.
there are two plugs, one is under where the check bolt is located and another is about 5 inches toward the front (this one is lower to the ground). Both take hex drives to remove.
which one do I remove to drain the diff fluid? What is the other one for?
Thanks.
Thanks.
