Hi,
My 2017 Yamaha Kodiak EPS has issues with oil consumption. It seems like once the oil has gotten a little dirty it starts to get used up. For example, I had ridden 300 miles and it was at the top of the safe zone on the dipstick. Then, after those 300 miles it’s either at the halfway point or slightly below it. I am just wondering why a liquid cooled machine is using this much oil. I do ride it mostly between the speeds of 40-50 mph. Currently, I have 15,800 miles on it. It has been using oil for quite some time now like this. I even checked the air filter from last ride and it seemed to be pretty clean. Also, I do use Lucas semi synthetic 10w-40 oil. In addition, I did check the valves recently and they were still in spec, except for one exhaust valve which seemed to be near the max of the in spec range. I did not bother to touch it since it was in spec. Also, the compression is good. It’s at approx 120 psi. The manual calls for 98-142. There is also no smoke as well. This leads me to believe it has something to do with the breather system possibly, like the reed valve? Please let me know if you have had similar issues.
Thanks 😊
Thanks 😊
