The middle child of the Kodiak family is the Kodiak EPS ($8,199). As the name suggests, this model boasts electronic power steering, handlebar light with high beams, new digital meter, KYB suspension with five-way pre-load adjustable shocks, and two-inch receiver hitch.
MSRP*
$8,649 - Realtree® Xtra® - Available from June 2015
$8,199 - Hunter Green - Available from June 2015
$8,199 - Steel Blue - Available from June 2015
$8,199 - Red - Available from June 2015
Engine Type -708cc liquid-cooled DOHC 4-stroke; 4 valves
Bore x Stroke - 103.0mm x 85.0mm
Compression Ratio - 10.1:1
Fuel Delivery - Yamaha Fuel Injection (YFI), 44mm
Ignition - TCI: Transistor Controlled Ignition
Starting System - Electric
Transmission - Yamaha Ultramatic V-belt with all-wheel engine braking; H, L, N, R, P
Final Drive - Lever operated 2WD/4WD; shaft
Chassis
Suspension / Front - Independent double wishbone; 5-way preload adjustment, 7.1-in travel
Suspension / Rear - Independent double wishbone; 5-way preload adjustment, 9.1-in travel
Brakes / Front - Dual hydraulic disc
Brakes / Rear - Multi-disk wet brake
Tires / Front - AT25 x 8-12 Maxxis® MU19
Tires / Rear - AT25 x 10-12 Maxxis® MU20
Dimensions
L x W x H - 81.5 in x 46.5 in x 48.8 in
Seat Height - 33.9 in
Wheelbase - 49.2 in
Turning Radius - 126.0 in
Ground Clearance - 10.8 in
Fuel Capacity - 4.76 gal
Wet Weight*** - 661 lb
Rack Capacity Front / Rear - 110 lb / 198 lb
Towing Capacity - 1322 lb
Lighting - Dual 30/30W headlights, 35/36.5W auxiliary light and 21/5W brake light
Warranty - 6 Month (Limited Factory Warranty)
Top Features
Advanced Instrumentation
New digital instrument panel boasts a multifunction LCD display with speedometer, odometer, dual tripmeter, hour meter, 4WD status, transmission position, clock and fuel gauge.
Class-Leading Power Steering
Yamaha’s Electric Power Steering provides the industry’s best balance of steering assist and positive feedback from the trail, providing maximum comfort and confidence.
Work-Ready Tow Capacity
Center-mounted, heavy-duty two-inch receiver comes standard and can tow more than 1300 pounds.
