2016 Yamaha Kodiak 700 MSRP*
$7,449 - Realtree® Xtra® - Available from June 2015
$6,999 - Hunter Green - Available from June 2015
$6,999 - Red - Available from June 2015
Engine Type -708cc liquid-cooled DOHC 4-stroke; 4 valves
Bore x Stroke - 103.0mm x 85.0mm
Compression Ratio - 10.1:1
Fuel Delivery - Yamaha Fuel Injection (YFI), 44mm
Ignition - TCI: Transistor Controlled Ignition
Starting System - Electric
Transmission - Yamaha Ultramatic V-belt with all-wheel engine braking; H, L, N, R, P
Final Drive - Lever operated 2WD/4WD; shaft
Chassis
Suspension / Front - Independent double wishbone; 7.1-in travel
Suspension / Rear - Independent double wishbone; 9.1-in travel
Brakes / Front - Dual hydraulic disc
Brakes / Rear - Multi-disk wet brake
Tires / Front - AT25 x 8-12 Maxxis® MU19
Tires / Rear - AT25 x 10-12 Maxxis® MU20
Dimensions
L x W x H - 81.5 in x 46.5 in x 48.8 in
Seat Height - 33.9 in
Wheelbase - 49.2 in
Turning Radius - 126.0 in
Ground Clearance - 10.8 in
Fuel Capacity - 4.76 gal
Wet Weight*** - 661 lb
Rack Capacity Front / Rear - 110 lb / 198 lb
Towing Capacity - 1322 lb
Lighting - Dual 30/30W headlights and 21/5W brake light
Warranty - 6 Month (Limited Factory Warranty)
Top Features
High-Tech Engine, Built for the Real World
The 2016 Kodiak™ 700 has an all-new 708cc, 4-valve, fuel-injected engine with optimized torque, power delivery and engine character—ideal for smooth, quiet operation all day long.
Ultramatic – The Industry’s Most Durable CVT Transmission
Kodiak 700’s Ultramatic transmission features a gated shifter, dual-range (Hi/Lo) drive plus reverse gear and is the most advanced drive system available – plus, the gear ratio and Kodiak-specific CVT settings are designed to lower engine RPM and provide a smooth, easy-to-use power character. An automatic centrifugal clutch maintains constant belt tension for reduced belt wear and a sprag clutch provides natural all-wheel engine braking.
Compact, Comfortable Chassis
The Kodiak 700 features a compact and comfortable new chassis with fully independent suspension, exclusively-designed 25-inch Maxxis® tires and wide arc A-arms providing optimum terrainability, comfort and handling.
Sharp Styling
The Kodiak 700’s styling features bright halogen headlights, large storage compartments and large-diameter front and rear racks with class-leading load capacity.
Work-Ready Tow Capacity
The 2016 Kodiak 700 has an all-new DOHC 708cc, 4-valve, fuel-injected engine with optimized torque, power delivery and engine character—ideal for smooth, quiet operation all day long.
