I bought a 2016 Kodiak SE recently and my first upgrade was a set of 26" Bearclaw tires. Having ridden 2-3 hundred miles on a different 2016 Kodiak that was all stock, I had a good point of reference for feeling what I felt was a pretty big difference with the 26" tires over the stock 25's. It felt lazy... especially in the mid-range... it felt slower to back-shift and it just didn't pull through 40-50 mph very strong. Top end was 64 MPH (would touch 65 occasionally), the stock one was a solid 65 hitting 66 once in a while.
I bumped the fuel mapping a bit to alleviate the lean running condition which makes the machine start and run better... I feel like I could notice improved throttle response. :smile2:
I also ordered a set of Yamaha 21 gram clutch weights (courtesy of a 2014 Grizzly 700). After changing oil (10W50 Yamalube) and filter for the first time (@ 165 miles) I swapped in the lighter weights.
I have noticed a massive change in mid-range... actually superior to the stock machine. This has more than compensated for the heavier 26" tires. In a zero-60 run I can stay pretty much exactly even depending who hits the throttle first. (Wife always jumps the gun... cheater
I am a bit confused though, I thought it would have a stronger bottom end too, but the stock gets me every time from a dead stop, about one-two lengths right off the line... If we hit it at about 15 MPH, then I pull away instantly a length or so.
It pulls much better throughout the rest of the range now... with the speedo jumping 2-3 numbers at a time... right up to 59 MPH or so, levels out around 63-64 MPH.
Overall I'm very happy with it, I didn't go 18 gram weights as I wanted to maintain quiet, lower RPM trail operation and the Kodiak's awesome fuel economy. So far... mission accomplished.
I am planning to add anti-friction washers to the secondary soon, and I might try JB's machined sheath in the future... to see if I can gain some hole shot capabilities without loosing top end.
