1 - 12 of 12 Posts
Yesterday I made my self up a tip for the exhaust, it sounds great but noticed that on start up it will run for a couple second them die, start it back up and it's fine. Also if you gun it from a stop it almost stalls out and back fires, but can ease into the throttle until wide open and it's okay just cannot go wide open from a stop anymore, I'm assuming this is all because of the tip? Done alot of reading and from what I gathered a fuel programmer wasnt needed for just a tip on the exhaust but I think I may need one.
I know that if you change the muffler on them that a programmer is needed or if you do tip and air box mods you need a programmer, but lots of guys say they havent had any issuse with just putting a tip on. I may run it for a bit see if things get better if not ill put the factory tip back on and run it and if it keeps doing it I'm lost haha.
You'll definitely need a programmer as your leaning out an already very lean running engine.
That makes sense to me. More airflow should need more fuel too.
Is there a thread on fuel programmers? What are the dependable brands and the ones to stay away from? What are the pros and cons of having one? If we don't have a thread yet I can start one instead of hijacking Kyerin's thread.
All that info is on Grizzlycentral.com
But yes starting a thread here would be an excellent idea. This forum is still in its infancy and needs ad much knowledge shared as possible.
I've done quite a bit of reading on the grizzly forums and lots of guys reccomend the ehs racing controller. But took the bike for a little ride today and pulled the yard trailer around a bit and it seemed to be fine wasnt running any hotter than usual and wasnt staling out after starting or with wot.
I'm gonna end up getting a programmer anyways, I'm in canada and bit harder to find a programmer but royal disturbing has the dobeck ejk I may try out, just for the fact that I dont have to pay shipping, border fees and instead of 300usd "which is almost 600cad" its 300cad so unless I can find a ehs programmer in canada I'm gonna go for the dobeck.
Ya hear ya, all us Canadians always face that same problems......
Discussion Starter · #10 ·
Well it's starting better now I reworked my tip made it more restrictive for more back pressure, but now if I go through water it will die and not want to start, made a snorkel kit last night just for the air box and it seemed to help a bit but it still will spit and sputter a bit after going through some water, I'm thinking coil pack?
Before you waste your money on a bunch of parts. Reinstall a stock tip first, and open all your submerged electrical plugs, inspect them, clean them if required, fill full of dialectric grease, replug everything and ride on...
Yep, put it back to stock and see if it stills happens. If not you may be chasing your tail
1 - 12 of 12 Posts
