Your Kodiak should be able to run without the stator output connector (has 3 A.C. wires) plugged in, as displayed in the first video. Even if the stator was not functioning, that shouldn't cause your current issue unless those A.C. wires were compromised and grounding out on the frame or engine case. The second plug "attached" to that stator cable set is the CPS and that does need to be connected as the engine will not even attempt to start without that signal. Not sure if you've gone through the partzilla videos, there are two that may help to get an idea of what may be going on with your machine. Also, since you have the 708cc, that is a different stator part number than the 686cc stator. Since the 708cc was only around for 3 years in the Kodiak/Grizzly, kind of not surprising RM Stator and Ricky Stator don't have a 3rd party version.
Yes, partzilla is using a first generation Grizzly 700 in these videos but a lot of the troubleshooting should be identical or very close to the same for your Kodiak. The obvious difference will be that you don't have a display for codes.
