I order my new tires from Amazon , i ordered 26x11-12 rear & 26x9-12 front. Tires came noticed they were about the same width 29x11-12 rear right, they sent 26x10-12 for the front? does anyone run 10" width on the front ? Or should i return them? thanks for your time and knowledge.
Regards, Jerry
Many do run 10" wide fronts. Usually 10 fronts and 12 rears or 10s all around etc..... You could certainly run them without issue. It comes down to what you want. I personally would prefer (and run) a 26 x9 fronts and 26x11 rear tire set up.
I ran my old Big Bear 350 with some 12" tires on the front and I'll never do that again. It is great as far as you go in a straight line but at sometime you are going to have to turn.
After that I won't run anything wider than 9 inches up front.
I returned the tires, Libra replaced them with 26x9-12's. Super great customer service. new tires at the house in 2 day's. 9's it will be.
Excellent! Happy you got what you wanted.
